My wall connections looked fine, but then I changed something and now they no longer seem to connect at the main wall layer correctly. How can I fix this?
Specifying an incorrect wall main layer, or wall setting for a wall type can be problematic when connecting different wall types to one another.
If the main layer was changed and your walls display the proper dimensions, please follow the steps in the To adjust General Wall Defaults section before completing the following steps.
In most cases, the main layer should be the structural layer, often the thickest layer within your wall.
If there is just one wall connection that is unique to your plan, you can use the Edit Wall Layer Intersection edit tool to change how that wall connects to other walls at that particular intersection. If you see that multiple intersections are wrong, you may need to adjust your Wall Defaults and Wall Type Definition. If multiple intersections are wrong please skip to the second and third sections in this article before trying the first.
If you only need to adjust specific wall connections and do not want to change the main layer of all walls of that type, use the Edit Wall Layer Intersection edit tool to manually snap the individual layer or layers of one wall to the layer of an intersecting wall. This is especially useful for additions.
If you have recently modified your wall types, you may have changed the main layer. In most circumstances, the main layer should be specified as the structural layer of the wall, particularly when the wall is a framed type. The main layer determines many things, including how walls join at intersections to the interior surfaces of their main layers. If you do not want your walls to move when you adjust the main layer of your wall types, you first need to adjust your General Wall Defaults.
These options determine what part of a wall retains its position when its wall type or wall type definition is changed. The Resize About location is also where any snap points will be located along a wall as it's drawn or connected to other walls, as well as where a wall's length is measured.
