How do I add a corner cabinet to a plan?
There are two ways to create a corner cabinet in Chief Architect.
- You can click near the intersection of two perpendicular walls to place a corner cabinet, or
- You can specify an existing cabinet as a corner cabinet.
For this example we will use a Base Cabinet, but you can use this same procedure to create corner Wall and Full Height cabinets
To automatically place a corner cabinet
- Select Build> Cabinet> Base Cabinet
- Once you choose a cabinet, the cursor will appear as a cross hair with the Base Cabinet icon
next to it.
- Position the cross hair in a corner of the room, making sure that it is as close to the corner as possible.
![Corner cabinet Placing a corner cabinet into a corner wall connection](https://d2haqc5836ials.cloudfront.net/live/KB-00330/330-fig1-11.png?1626464996)
- Click the mouse button once and a diagonal-shaped cabinet should display in the corner.
To specify an existing cabinet as a corner cabinet
- Click on a cabinet to select it and click the Open Object
- On the General panel of the Cabinet Specification dialog that opens:
![General panel of the Base Cabinet Specification dialog Selecting the Corner Cabinet Style Type](https://d2haqc5836ials.cloudfront.net/live/KB-00330/330-fig2-11.png?1626464996)
- Change the Width value so that it is greater than the Depth value.
In this example, the Width is changed to 36" while the Depth remains at 24".
- Select Corner from the Cabinet Style Type drop-down list.
- The cabinet will now become a corner cabinet, regardless of how it was originally created.
To set this corner cabinet as a Lazy Susan
- Select the Cabinet and click on the Open Object
- On the General panel of the Cabinet Specification dialog, and under Options, place a check next to Lazy Susan to indicate a lazy susan in the cabinets label and its appearance in floor plan view.
![Floor plan view of a corner cabinet with a lazy susan Lazy Susan corner cabinet](https://d2haqc5836ials.cloudfront.net/live/KB-00330/330-fig3-11.png?1626464996)
- If you would like the corner cabinet to have a standard front, remove the check from the Diagonal Door checkbox, then click OK.
