How do I use the Space Planning Assistant to layout a new floor plan?
The Space Planning Assistant allows you to start a new floor plan by creating and arranging 2D room boxes. Once the boxes are laid out, the Build House tool will convert them to walls and rooms that can be edited and detailed to completion.
To use the Space Planning Assistant
- From the menu, navigate to Tools> Space Planning> Space Planning
to open the Space Planning Assistant.
![Welcome screen of the Space Planning Assistant](https://d2haqc5836ials.cloudfront.net/live/KB-00349/349-fig1-13.png?1629149727)
- The Assistant will prompt you to enter the number of floors you want, the garage properties, as well the type of rooms you'd like for each floor level.
- After selecting Finish in the Assistant, individual room boxes will appear on each floor level based upon the properties you've specified.
![Space Planning rooms generated in the plan](https://d2haqc5836ials.cloudfront.net/live/KB-00349/349-fig2-13.png?1629149727)
Similar to other objects in Chief Architect, room boxes can be selected and opened to specification. Several attributes, such as the Room Name, Function, and Size of the box, can be adjusted to your liking.
- If additional rooms need to be added, select Tools> Space Planning
from the menu, select the room type you'd like to add, then click in the plan to place it.
To delete a room, select it using the Select Objects
tool, then click the Delete
edit button or press the Delete button on the keyboard.
- Once all of the rooms you need for your home are on the plan, they can be moved and resized to your liking.
To move a room, select it using the Select Objects
tool, then use the square Move
edit handle that displays in the middle to move it to the desired location. To resize a room, click on one of the side edit handles and drag it to enlarge or reduce the size.
![Space Planning rooms that have been moved and resized](https://d2haqc5836ials.cloudfront.net/live/KB-00349/349-fig3-13.png?1629149727)
- After the rooms are positioned and correctly sized, select Tools> Space Planning> Build House
on each floor level. The room boxes will be converted into walls and rooms, and doors will be created. If Auto Rebuild Roofs is enabled, automatic roof planes will also generate.
![Walls, rooms, and doors have been generated](https://d2haqc5836ials.cloudfront.net/live/KB-00349/349-fig4a-13.png?1629149727)
- Select 3D> Create Perspective View> Perspective Floor Overview
to see the results.
![Perspective Floor Overview of the structure](https://d2haqc5836ials.cloudfront.net/live/KB-00349/349-fig5-13.png?1629149727)
- Additional modifications can now be made to the generated walls, doors, and rooms. You can also add additional room boxes at anytime, then perform step 6 again to generate additional walls, doors, and rooms in the plan.
