I would like to design a solarium. How can I do this?
There are various approaches to designing a solarium, greenhouse, or sunroom. As this article explains, you can create a solarium using metal framing, windows, and skylights.
To create a solarium wall type
Select Build> Wall> Define Wall Types
- In the Wall Type Definitions dialog, click the New button to create a new wall type.
- Give your new wall type a short, descriptive, unique name so that it can be easily identified later.
- Specify the desired Thickness of your steel wall.
For the purposes of this example, a Thickness of 1 1/2" is specified.
- You may find it helpful to specify a line Weight that is less than the By Layer value.
To do this, select the wall layer, then specify a Line Weight value.
- Click the Material column to the right of layer 1, browse to Materials> Framing, select a steel stud material for your walls, then click OK.
- Make any changes you would like to the Line Style or Fill Style, but bear in mind that your steel wall will be thin, so these changes may not be visible when you are zoomed out.
- The new steel wall type is now available to replace existing walls in your plan.
- Click on a wall to select it, then click the Open Object
- On the Wall Types panel, select the newly created type from the Wall Type drop-down list.
- In this example, three exterior walls of the attached structure are changed to the newly created steel wall type. This solarium room has also been opened to specification and the flat ceiling has been removed by unchecking the Flat Ceiling Over This Room box on the Structure panel.
- If you wish to draw new walls using this wall type, you can do so by specifying it as the default for your Exterior Wall
or Interior Wall
tool.
from the menu, and in the Default Settings dialog, expand the Walls category, click on Exterior Wall or Interior Wall and click the Edit button.
- In the Exterior/Interior Wall Defaults dialog, specify your steel wall type on the Wall Types panel, then click OK.
To create a solarium roof system
- Before building the roof planes, we'll adjust our roof settings in the Build Roof
dialog. For this example, the following settings will be used:
- Now that the roof settings are adjusted, the roof can be generated using the Build Roof
dialog or by building it manually using the Roof Plane
tool. In this example, a gable roof was generated by using the Build Roof dialog.
For more information on creating different roof styles automatically, please see the Related Articles section below.
To add skylights to a solarium roof
With the roof placed over the solarium room, skylights can now be added to create the finished glass solarium roof. We'll make use of Multiple Copy and the Reflect About Object edit tools option to replicate a skylight and duplicate them across the roof.
- Select Build> Roof> Skylight
from the menu and place a skylight. After placing the skylight, make any necessary adjustments to the size and the frame. In this example, the Frame has been adjusted to a Width of 1" and a Height of 1/4" on the General panel.
- Select the skylight and use the Multiple Copy
edit button located on your edit toolbar to create several copies of the skylight as shown below.
- Select the skylights in the roof plane and use the Copy/Paste
edit button with the secondary edit button, Reflect About Object
, to copy the design over to the neighboring roof plane.
Objects can be group selected by holding the Ctrl or Command key and left clicking on objects us creating a selection marquee. For more information on group selecting objects, see the Related Articles section below.
To add glass to solarium walls
With the steel walls and roof in place, it's time to place windows in the steel walls to create our glass solarium walls. We'll follow a process similar to the previous steps replicating the skylights.
to create an exterior elevation of either the north or south wall of the solarium.
- Select Build> Window> Window
to place a window in the solarium wall and make any necessary modifications. For this example, the following settings are used:
- On the Casing panel, the Interior and Exterior Casing are removed.
- On the Lintel panel, the Interior and Exterior Lintel are removed.
- On the Sill panel, the Interior and Exterior Sill are removed.
- On the Sash panel, the Sash is removed.
- On the Frame panel:
Sides, Top, and Bottom Width are set to 1/2".
Fit Frame to Wall is unchecked.
- The Depth is set to 1 1/2" and the Inset is set to -1/4".
- On the Framing panel, the Rough Opening values for Each Side, Top, and Bottom are all 0".
- On the Materials panel, all components of the Window are using the Steel Stud 16" OC material, apart from the Glass.
- Select the window placed in the solarium wall and use the Multiple Copy
edit button to replicate the window across the wall at your desired interval.
- Group select the windows. To do this, navigate to Build> Window> Window
from the menu, hold down the Shift key on the keyboard, and using the left mouse button, click and drag a selection marquee. With the windows selected, use the Copy/Paste
edit button to create copies and paste them on the adjacent walls.
