I am having trouble downloading library catalogs, where one of the following messages display:
"Part of the catalog download/update has timed out. Please check your network connection and security settings. If connecting via wireless, try plugging directly into modem/router and then downloading again. Would you like to try downloading again?"
"Security software or a firewall is blocking the program from accessing the catalog download server. Please re-configure and try downloading the catalog again."
"The catalog download/update completed with one or more errors. Would you like to try downloading again?"
"The catalog download/update completed with one or more errors. This could be caused by internet connectivity, firewall settings, etc. Would you like to try downloading again?"
"The catalog could not be found on the server."
Why is this occurring?
If you encounter one of these messages, one of these is likely to be the cause:
If you're having trouble downloading the core catalogs, you can manually download and install the files for your specific product, or install them from the program's backup media, if purchased using the instructions below.
Please select the link that coincides with the Chief Architect product you're using:
If you have physical backup media such as a DVD disk or a USB Flash drive, you can also install the core catalogs directly from the media. Please see the "Installing Library Content from Physical Media" resource in the Related Articles section for more details.
If you'd like to purchase physical backup media, please contact our Customer Service team directly.
Chief Architect Premier X16 Data
