What is the best method for creating a completely custom glass shower enclosure?
Several already existing shower and bathtub combinations, as well as enclosures, can be located in the Library Browser. However, if you're designing a glass shower that requires custom modifications, it's recommended to utilize the Glass Wall and Glass Shower Door tools instead.
To learn more about modifying walls and their various properties, please see the Related Articles section below.
A shower wall niche can also be created inside a custom shower by navigating to Build> Window> Wall Niche from the menu, and clicking along a wall to create the cavity.
Fixtures can then be added to complete the space. Navigate to Chief Architect Core Catalogs> Architectural> Plumbing Fixtures within the Library Browser to find faucets, shower pans, drains, and other fixtures to place into your custom shower. Additional shower fixtures and hardware can be found in the various manufacturer and bonus libraries located in the 3D Library.
Additional tools, such as the Custom Backsplash and Wall Material Region
tools can be used to apply decorative tile or other materials to certain areas of the shower, while the Soffit
and 3D Solid
tools can be used to create objects like benches or shower curbs.
Here are just a few of the different shower configurations that have been designed in Chief Architect using the tools and techniques mentioned in this article. These examples, along with several others, can be accessed at anytime from the Chief Architect Samples Gallery.
