In X13 and prior program versions, I used the NKBA Auto Dimension tools to generate dimensions that met the NKBA standards. I no longer see these tools in X14 and newer versions. How can I generate automatic NKBA dimensions?
The NKBA Auto Dimension tools have been merged into the Auto Dimension tools to add more flexibility and customization to Kitchen and Bath dimension functionality. To create automatic dimensions that follow NKBA standards in a plan created using an X14 or newer version template, use the "Kitchen and Bath Dimension Defaults" in unison with the Auto Dimension tools.
Since the NKBA Auto Dimension tools were not tied to a specific Dimension Default, if you migrate a plan or template created in a prior version into X14 or a newer version, a new Dimension Default called "Legacy NKBA Dimension Defaults" will be created. If you used the NKBA Auto Dimension tools for your Kitchen and Bath plans and elevations in a prior version, we recommend switching to this Dimension Default for these views.
It's important that you're always using the Dimension Default that is intended to be used prior to generating dimensions lines.
