I'm experiencing one or more of the following issues when I attempt to open my Chief Architect program after updating my Mac to macOS Sequoia (15):
What might be the cause of this behavior?
On Mac computers, a feature called Private Wi-Fi address, which was introduced in macOS Sequoia (15), may cause issues with activation or authentication if you're connected to a network wirelessly.
If you are met with an error relating to license activation or authentication and you are using Chief Archiect X16, Home Designer 2025, or a newer version, this issue can be resolved by downloading the latest program update:
If you are using Chief Architect X15, Home Designer 2024, or a prior version, and your Mac has macOS Sequoia (15) installed, you will need to disable this feature for each individual network that you connect to wirelessly to prevent constant authentication issues. The instructions below discuss how to disable this feature.
*Applies to macOS Sequoia (15) and newer.
This setting must be disabled for every individual network that the system connects to wirelessly; this problem will reoccur if this feature is not disabled after connecting to a new or different network.
If you have followed the steps listed above and are still unable to activate your Chief Architect license, or you are not connected to a network wirelessly, it's possible that something else may be the cause. Please refer to the "Troubleshooting Activation Issues" resource in the Related Articles section below to troubleshoot the issue further or contact Chief Architect Technical Support.
