I'm building an unfinished garage with exposed studs. How do I get these walls to display the framing properly in a camera view.
![Full camera view displaying exposed wall studs inside of a garage Garage with exposed wall framing](https://d2haqc5836ials.cloudfront.net/live/KB-03045/3045-prettypic-13.png?1626470968)
To see exposed studs, create a custom wall type with no interior wall layers, then turn on the display of the "Framing, Wall" and "Framing, Headers" layer(s) while in a camera view.
To display exposed wall studs
- Create a New Plan
or Open
an existing plan where you want to see walls with exposed studs.
- Navigate to Build> Wall> Define Wall Types
- In the Wall Type Definitions dialog that displays:
![Wall Type Definitions dialog with a custom wall type defined](https://d2haqc5836ials.cloudfront.net/live/KB-03045/3045-fig1-13.png?1626470968)
- Click on the Wall Type drop-down menu located in the top left corner to choose a wall type that contains a framing layer.
In this example, the Siding-6 wall type was selected.
- Select the Copy button to copy the wall type that was selected, then give it an appropriate name.
In this example, the name is set to "Siding-6 Exposed Studs".
- Select any Interior Layers that exist in this wall type, then click the Delete button on the right to remove them from the wall.
In this example, a single Drywall Interior Layer was deleted. The Interior Layer containing a line style cannot be removed.
- Make any other desired modifications to the wall type, such as changing the materials and thickness of the Exterior Layers, then click OK.
For more information on customizing and defining wall types, along with the various settings located in this dialog, please see the "Defining a New Wall Type" resource in the Related Articles section below.
tool, click on the wall or walls that you want to display studs for, then click on the Open Object
For more information on selecting multiple objects at once, please see the "Group Selecting Objects" resource in the Related Articles section below.
- In the Wall Specification dialog that appears, select the Wall Types panel, choose your custom wall type using the Wall Type drop-down menu, then click OK.
![Wall Types panel of the Wall Specification dialog where a wall type can be selected](https://d2haqc5836ials.cloudfront.net/live/KB-03045/3045-fig2-13.png?1626470968)
- Create an interior Camera
view looking towards one of the walls utilizing the custom wall type.
- If wall framing is not set to automatically rebuild, navigate to Build> Framing> Build Framing
while the camera view is active.
- On the Wall panel of Build Framing dialog that displays, place a check in the Build Wall Framing box, then click OK.
You may receive a message stating the "Framing, Wall" layer is not displayed in the current view. Click Yes to see the wall framing in the camera view. You may receive a similar message regarding the "Framing, Headers" layer.
![Wall panel of the Build Framing dialog](https://d2haqc5836ials.cloudfront.net/live/KB-03045/3045-fig3-13.png?1626470968)
- Select 3D> Rebuild 3D
to update the view and see the results.
![Full camera view of an area with exposed studs.](https://d2haqc5836ials.cloudfront.net/live/KB-03045/3045-fig4-13.png?1626470968)
If this wall type will be utilized in future projects, consider selecting a wall that is utilizing the custom wall type, then clicking the Add to Library edit tool. The wall will be added to the User Catalog folder within the Library Browser and can be selected and used to create new walls in your plans, similar to how the Wall tools work in the program.
