I am working on a large plan, and I notice that the program is working very slowly, is sluggish or seems to lag or stall. Is there something that can be done to remedy this?
In this article, we will discuss the most common reasons for encountering slowness in Chief Architect plans.
Before completing these steps, please check to makes sure that any other software running on the computer or in the background is needed, and exit any other programs that you may not need to have open while working in Chief Architect.
Please make sure to review all of the information in this article, as the cause of slowness that you may be encountering could be related to more than just one of the items listed below.
Work on Files Locally
By far, the most common reason for slowness is working in an unsupported fashion, such as over a network server location, external hard drive, or USB flash drive.
In addition to experiencing slowness working in files, working in this type of unsupported fashion is hazardous because it can lead to file corruption and data loss.
For these reasons, it is critical always to work on files that are saved on your local hard drive. This means that you should copy the file from a network server, external hard drive, or USB flash drive location to your computer's hard drive before opening it in the software. Then, make your changes, save the file, exit the program, and then copy the file back to its network server, external hard drive, or USB flash drive location.
If you are working on your computer's hard drive, and are still experiencing slowness, then please continue with the information provided in this article.
Verify System Requirements
If you are working on files locally, the next step is to verify that your computer meets, or better yet, exceeds, the minimum system requirements for running your version of Chief Architect.
The system requirements for the current version of the software can be located online at: https://www.chiefarchitect.com/products/sysreq.html
- If you primarily notice slowness with regards to 3D Camera views, check to see what video card is in your system. Please see the Locating your Computer's Specifications Knowledge Base article to learn more.
If your video card only just meets the minimum system requirements, then you may want to look into replacing it with a video card that is mentioned in our recommended system requirements.
- Update your video card's driver by following the instructions in the Troubleshooting 3D Camera View Display Problems in Chief Architect Knowledge Base article, then verify that the appropriate card and driver are listed in Chief Architect's Preferences
under the Video Card Status panel.
- If you are using multiple monitors, make sure that your system's video card fully supports this functionality.
You may experience slowness, particularly with 3D camera views as well as library and dialog previews if the video card is taxed by three or more monitors as well as the rendering. You can test shutting the system down, disconnecting the extra monitors, restarting the system, and then attempt to run Chief Architect on a single screen to see if speed improves.
- If you are looking into purchasing a new system and want to make sure that it offers good performance, please view both our recommended system requirements and our Chief Blog article.
Simplify Fill Styles and Patterns
Avoid using complex fill styles and patterns extensively in your plan and CAD Details.
- If you use a custom Fill Style that requires drawing many tiny lines on the screen, this can substantially slow down working in floor plan view for such tasks as zooming, moving, and placing objects.
Particularly for elements of your design such as the layers of your wall type definitions, roof planes, closed polylines, rooms, and landscaping features, try to avoid the use of many fill patterns.
- Material patterns, such as complex stone or tile patterns, in views which utilize the Vector rendering technique, such as Cross Section/Elevations and Orthographic Overviews, will also slow down the generation of the view as well as actively working in it.
- If you must add these types of detailed CAD elements for hatching and fills to your design, make sure to do so as one of the final steps when your plan is near completion, before creating the layout, and expect to encounter slowness with the file after doing so.
Slowness in 3D Views
Avoid working with multiple 3D camera views open. Every time you make a change to the plan, the program will redraw the entire model. Depending on the complexity of the design, this may take a long time.
You can see how many view windows are open by selecting the Window menu. Open view windows are listed at the bottom of the menu.
If you are using the Generated Sky setting, keep in mind it takes into account the orientation of the sun, so if you've set the sun to follow your camera, then the generated sky will regenerate each camera movement to account for the new sun direction, which can cause slowness in 3D camera views.
Manage Displayed Layers - If you need to work in 3D views, turn off any layers that aren't necessary for the task. This will improve your redraw time.
For example, if you need to work on landscaping or roofs in a Full Overview, consider turning off the layers for Fixtures and Furnishings in the appropriate layer sets.
In elevation and plan views, if you use a high number of macros in text or labels that are displayed, this can slow down panning, zooming, and moving objects in these views.
Manage 3D Surface Count - Avoid importing 3D objects from outside sources that have a large number of complex surfaces, as these can significantly slow down camera views.
To check the number of surfaces for imported symbols, using the Select Objects
tool, click on an imported symbol to select it. Next, click on the Open Object
edit tool in X15 and newer versions or Open Symbol
in X14 and prior versions. On the 3D panel, take note of the Number Of Faces and then Cancel out of the dialog without making any changes.
If you aren't certain whether or not a symbol has an unusually high number of faces, you may want to repeat this procedure on a similar type symbol placed from the Chief Architect catalogs and compare the Number Of Faces.
Control Pictures and PDF files Saved in Plan/Layout
By default, picture files and PDF files are referenced from outside of your Chief Architect file. You can, however, open the Specification dialogs for both of these types of objects and check the Save in Plan option to embed the picture, or PDF, in the plan. If you chose this option, it could cause a significant slowdown when working in the plan or layout file.
Instead of saving pictures or PDF files in the plan, the recommended method for transferring a file between computers, or to another individual, is to use the Backup Entire Plan/Layout
feature to ensure that no data is lost that would result in a missing file message. This feature not only allows you to export the picture and PDF files along with the plan and layout, but also all of the associated custom backdrops, materials, and images you may be using for the file. For more information on using this tool, see the Related Articles section below.
Manage Live Views in your Layout
When you send a cross section/elevation, camera view, or overview to your layout, you have the option to select Live View to make the view dynamically linked to the plan file. You can also select for this view to Update On Demand or Update Always.
Selecting Update Always can potentially contribute to slowness in your plan. To change a view so that it only updates on demand, select the view in your layout, then click the Open Object
edit button to open the Layout Box Specification dialog. On the Linked View or Camera View panel, select Update On Demand, then click OK.
Purge Unused Data
In addition to the suggestions above, if you have been using a file through several versions of Chief Architect, you may have unnecessary leftover data such as unused CAD Blocks, materials, and layer sets that can be removed to reduce the overall size of your plan file.
It's important to always start a new plan or layout file from a template. If you are unfamiliar with setting up template files, please review the appropriate resources located in the Related Articles section below.
- To purge unused CAD blocks, select CAD> CAD Block Management
from the menu. In the CAD Block Management dialog, there is a list of all CAD blocks referenced in your plan.
- Click the Purge button to delete any unused block definitions from the list.
- You can also click on an unused CAD block in the list, then click Delete to remove it from the list.
- Check the Automatically Purge CAD Blocks box to prevent unused CAD block definitions from being saved in the plan.
- When you're done making changes, click OK to close the dialog and apply the changes, then Save the file.
- To purge unused materials from your plan, select 3D> Materials> Plan Materials
from the menu to display the Plan Materials dialog. The list on the left includes all materials present in the plan.
Click the Purge button on the right to remove any unused materials from the list.
You can also select an individual unused material from the list and click the Delete button.
- To manage layer sets, select Tools> Layer Settings> Layer Set Management
to open the Layer Set Management dialog. Use the Available Layer Sets options to manage the layer sets saved with the current plan or layout file.
- Click the Delete button to delete a selected layer set from the current file.
The Delete button is only enabled if the layer set can be deleted.
Do not delete layer sets that are used in views that were previously sent to a layout file.
Disable Auto Rebuild Options
There are several settings within the program that affect rebuilding, which can slow down a complex plan if they are constantly having to be regenerated after every change. For speed purposes, you may want to turn off these auto rebuild settings, and only turn them back on when the plan is close to completion.
Automatically Rebuild Foundation - This setting can be accessed by selecting Edit> Default Settings> Foundation.
On the Foundation panel, uncheck Automatically Rebuild Foundation to stop the foundation from rebuilding every time you make a change on the first floor. Please note that you will then have to manually update the Floor 0 level, or remember to turn the feature back on later in the design process.
Automatically Build/Rebuild Framing - There are several settings relating to the automatic generation of framing, which can be accessed by selecting Edit> Default Settings> Framing in X15 and prior versions, or Build> Framing> Build Framing in X16 and newer versions.
In X15 and prior versions, go through every individual floor panel, starting on the Foundation, up to 1st, 2nd, etc and uncheck the checkboxes near the top of the dialog for Automatically Build Floor and Ceiling Framing. On the Wall panel, uncheck Automatically Build Wall Framing. On the Roof panel, uncheck Automatically Build Roof Framing.
In X16 and newer versions, uncheck the Automatically Rebuild Framing box, and ensure that all of the subcategory boxes are unchecked.
Auto Rebuild Roofs - This setting can be accessed by selecting Edit> Default Settings> Roof.
On the Roof panel, uncheck Auto Rebuild Roofs. Any future changes made to the plan while this setting is disabled will not affect the roof, so you will need to either modify or add roof planes manually, or wait until the plan is nearer to completion to turn the setting back on if it significantly slows down your ability to work in the plan.
If you have a complex terrain that requires rebuilding when you make changes, select Terrain> Terrain Specification
and remove the checkmark from Auto Rebuild Terrain.
When you click OK, you will notice that your mouse cursor now has an image of the Build Terrain
setting following it to remind you that your terrain may not be up to date.
Select 3D> 3D View Defaults
. You can turn off Auto Rebuild Walls/Floors/Ceilings at this location. While this may speed up changes you make to your plan, it is extremely important to remember that it also means that your 3D camera views may not accurately reflect changes that you have made to the plan view.
You can disable this setting for troubleshooting purposes, however, expect that when this is unchecked and the structure is not up to date, the Rebuild Walls/Floors/Ceilings
icon will display next to your mouse cursor.
Again, if these changes offer speed improvement in working with your complex plan, you will need to remember to manually rebuild the various options, or to wait until the plan is near completion to turn the automatic settings back on.
ADVANCED TROUBLESHOOTING
If you have completed all of the troubleshooting steps listed in this article and still have not been able to determine the cause of the slowness in your plan, then please submitall of the following information to Chief Architect's Technical Support team for advanced troubleshooting.
When you notice the slowness, take a moment to write down what you were doing. Include what views you had open, what tools you were using, and what types of objects were being added, edited, or removed.
For example, joining two particular roof planes, modifying a CAD Detail by breaking lines, editing doors/windows while a 3D camera view is open, rebuilding framing, etc.
If the issue only seems to occur in one particular file, use the Backup Entire Plan/Layout
tool to create a folder with a copy of the problem file, along with all referenced files.
See Knowledge Base article: Using the Backup Entire Plan/Layout Tool to Send Files to Another User.
If you are receiving an error or warning dialog box, make sure to first search this Knowledge Base for the exact wording of the error, or click on the Check KB button in the message if one is present, as there may be specific information relevant to that error in another article. If you are unable to locate any additional information on the error, make sure to attach a screenshot of the message.
Locate and save the program's Message Log file.
Export or save your System Information.
- Sign in to the Technical Support Center and create a new support case to send to Technical Support.
Give the case a short but descriptive title.
In the text of the ticket, type a detailed description of the problem, including the exact steps that caused the slowness to occur if at all possible. The more detailed you are, the more likely we will be to reproduce the issue and identify the problem.
Click the Browse button and attach the Project Backup, Screenshot, Message Log, and System Information files to your case, then Submit it.
